Case similar to this?
Do you have any particular price range? ^_~
Any how many drive bays do you need? =S
Or any particular features you want, other than good airflow.
EDIT1: Also, Full tower or Midi tower?
EDIT2: Possibly something like this : aria.co.uk/Products/Components/Cases/MIDI+Tower/Nexus+Clodius+Midi+Case+?productId=30298
Price range: Cheap as possible - being a student...deffo under £100
Drive bays...hmm..two at max
Features...not very long in depth but other than that as long as it isnt tacky/thermaltake xP
Ummm preferably not full tower - im trying to save space - small room
name='Bobalob' said:
Take a look at some of the Coolmaster cases like the ( HAF 922 )
Yeh I have mate, its just a bit too long in depth but seems I may just have to have it jutting out a bit
The k58 is really similar to this but without the two top fan you can buy the fan and use the hdd drive grommet.
The price is £45 at newegg
anyone wanna just shout about 5 good small cases to check out? the scout storm has crap cooling by the looks of it (im looking for 120mm fan solutions at least)
seems fine to me, houses up 2 5x120 fans and for the size of the case and the price aswell the cooling is suitable.:P
