I am soon going to be building a new computer for my parents as the current one (P3 750 GF3) doesnt quite cut it anymore, and so i am looking for a new case.
This is proving more difficult than i had thought. I am looking for:
Midi case (PC60 or a bit larger)
ATX not BTX
120mm intake and exhaust (intake has decent airflow, not having to draw up from the floor to keep the front fascia clean from holes)
Decent looking
Fan filters preferred by not necessary (can always stick some tights over the fans)
Cases i have already looked at and rejected:
Lian-Li PC7 PLUS - 80mm exhaust
Coolermaster Wavemaster - 80mm fans all around
Coolermaster Cavalier 3 - 80mm intake
Silverstone Temjin TJ04 - No decent intake for front fan
Silverstone Temjin TJ05 - I REALLY thought this was the case for me, looks great, 120mm fans, filters but then i looked at the dimensions and for some crazy reason it is 617mm deep! (a good 12cm deeper than a PC-60) so i cant fit it under the desk without it sticking out too far.
I didnt think my list of desired options was that crazy but my searcing is proving me wrong,.
So, long story short, can anyone recommend me a case that will suit my needs?
G
ATX not BTX
Decent looking
G
