ExpertLayman
Member
Hello can someone tell me which of these memory cards is best and why. The prices are about the same:
My gut instinct tells me to go with the lower latency (Redline Ridgeback).
A few more question:
Taken from : How memory frequency affects latency - Tighter timings vs. Higher speeds?
Second example
Taken from: Understanding Memory Timings
I've read them several times and I still don't understand where the numbers are coming from.In both cases the one with high speeds is the better option when moving large amounts of data. And considering I am going into 3d modelling and video/photo editing, I expect large amount of memory usage.
I would really appreciate an explanation of the articles equations.
Thanks
Mushkin 6GB (3x2GB) DDR3 PC3-12800 6-8-6-24 Redline Ridgeback - 998970
Capacity 6GB (3x2GB)
CAS latency 6-8-6-24
Memory speed DDR3-1600Mhz (PC3 12800)
Test voltage 1.65v
Warranty Limited Lifetime Warranty
Mushkin 6GB (3x2GB) DDR3 PC3-16000 8-10-8-27 Radioactive - 998966
Capacity 6GB (3 x 2GB)
CAS latency 8-10-8-27
Memory speed DDR3 2000Mhz (PC3 16000)
Test voltage 1.65v
- Does it matter if I choose buffer and unbuffered RAM?
- Do you think I need ECC if I am into video/photo editing and 3D modelling. I know I don't need to worry about it in games.
- And the final question can someone explain where the equations and number are coming from and how I can measure them to figure out was best from the following:
PC-4200 -> DDR-533 -> 266MHz base frequency
266MHz = 266 million cycles per second -> 3.76 x 10-9 sec per cycle (3.76 ns)
CL 3 = 3 x 3.76 ns = 11.28 ns
CL 4 = 4 x 3.76 ns = 15.04 ns
CL 5 = 5 x 3.76 ns = 18.80 ns
Second example
- CAS Latency for DDR3-800 6-6-6-15 = 6 / 100 MHz = 6*10**-8 seconds
- CAS Latency for DDR3-1333 9-9-9-24 = 9 / 166 MHz = 5.4*10**-8 seconds
Thanks
