Can not shut down match II
CYK
Hello,
I have a problem with my match II unit.
It won't shut down, usb controler does not recognize it, and it automaticly starts up whan I put AC cord in it. All 4 led diodes are on and the green one is tilting.
When on, it is working fine, but if enzone can help me with this problem i will appreciate it
Common issue that can be resolved is the firmware has corrupted - assuming that you wired it up okay and they way that you have it connected now allowed the unit to work correctly beforehand.
Reload the firmware and you should be okay - if not your controller card is probably borked and you then have two choices:
1) Live with it and switch it on/off manually.
2) buy a new controller board.
Hope the firmware update works, had to do mine about 4 times and so far (touch wood) its worked.
Can you list your PC spec here too so that we can eliminate any other hardware related issues.
By the way, welcome to the forums.
Mav
Thank You for quick respond.
I will tray to flash firmware, but I'm in doubt that it will works becouse my control centar can't see
my match.
My rig:
CPU: QX6700, Q6600 (I'm testing which one is better)
RAM: 4x 1GB D9GMH
MB: Blitz Formula
GPU: 8800 GTX
Sound: Audigy 4
HDD: 6X Baracuda 320GBs
PSU: Galaxy 1KW
WC: GPU and NB with (swiftech MCP 655, MCW60, FB on board, 3x120 Swiftech Radiator)
my match.
My rig:
RAM: 4x 1GB D9GMH
MB: Blitz Formula
GPU: 8800 GTX
Sound: Audigy 4
PSU: Galaxy 1KW
Make sure that you have the USB header is connected properly - it should be conneted on the row with 4 pins with the black wire connected on the pin next to the spare where a fifith pin is on the 2 row of the header - that should work then.
Of course you should have XP SP2 installed so the usb works correctly.
Cheers
Mav
Mav thanks for help I fix my problem with updateing to 937 firmware.
It 's for GT model but works fine on mine too.
Where can I ask about regasing unit and advice for anything else to do to get my CPU more cool?
Best Regards
from Serbia
