I've been having real problems with my AMD 3800+ X2 system (XP SP2). I've stopped overclocking, but the problem persists.
My PC often gets to a state where it pauses for about 6-10 seconds. Sometime this happens as often as every 30-60 seconds. Eventually, it locks un completely and requires a reboot.
I've tried all sorts of thing, and eventually looked in the event viewer, and found the following:
I think that seems to be the problem - the pattern seems to match what I'm experiencing. Can anyone suggest what's causing it, and how I can fix it?!
