Call of Duty 5
k4p84
Hey all,
Just installed the game.
I am getting a lot of issues with the graphics.
In the second level where you come ashore all the layers are broken / ontop of one another.
Running sli GTX 280
Everything is maxed on the settings.
I know it's a brand new game etc so bugs are to be expected but can anyone think of anything to change to improve this?
ED
Play.com, always get it a day early.
Latest drivers.
I have no issues with any other games.
Maybe there will be a patch released asap.
I did not get the beta to test, so i cant be sure if it's the game as a whole or just something i should turn down.
Spot the slight / complete copy of a scene from Enemy at the Gates...
lol
Its not the best of games but it's keeping me amused.
ED
driver hunting as we speak.
I had though that it would not be sli happy but i presumed then it would just not scale well with two cards.
Does that sound like a reasonable conclusion or would it infact cause visible issues?
ED
Oh for pete's sake.
Just upped the drivers, rebooted....
Goes through post........windows vista loading bar........
Then black screen.
Pc is running fine, i hear all the windows loading sounds and the keyboard is light etc. Just lack of picture.
Anyone know how to get my picture back!!
ED
Did you uninstall the previous drivers before installing the new ones?
When starting your computer, hit and hold F8 to bring up the menu that will let you boot in to safe mode which will start windows with its default video drivers, and not the ones causing you problems.
Then uninstall the duff new ones and either try them again or find others or go back to your previous version.
1.1v Patch
Code:
“Changes:
- Mods are now enabled in Co-op, Single Player, and Multiplayer.
- Players will now be notified when a new patch is available.
[B]- Improvements for SLI support.[/B]
- G_Spawn: no free entities crash has been fixed.
- Server no longer runs out of script variables.
- License key is no longer required to run a Dedicated Server.
- A Dedicated Server can now be started from the Command Line via Remote Desktop Connection.
- Various fixes in Server Browser.
- Players will no longer see multiple friend invites from the same friends.
- When a player calls in a recon plane in a Hardcore match, the HUD will properly appear.
- Clan Tags will now display in game where appropriate.
- Map holes fixed
- Spawn improvements and weapon balancing
- remote desktop now works with dedicated server”
download from:
http://www.ausgamers.com/files/details/html/40158
http://www.gamershell.com/download_35712.shtml
that was quick :D
name='kataras' said:
1.1v Patch
Code:
“Changes:
- Map holes fixed
download from:
