tolagarf
Member
I'm looking to exchange my memory (currently Corsair DDR4-2400 CL14) since the current ones for some reason hate my guts. But I can't run my memory at 125 MHz FSB, since this will make my CPU run quite a bit hotter with this Noctua NH-U12S cooler. And I'm wondering which memory to get that will operate best with my i7 5930K.
I tried looking for websites that can calculate the FSB Ratio of RAM, but the only one I found was last updated in 2011, so I'm not sure it's up to date on DDR4 memory. What I'm looking for are speeds that run 100 MHz on the FSB, because from what I can gather this is what my CPU operates best with.
Also I'm considering SLI down the road (instead of upgrading every year), and I know that memory with high speeds can give a huge FPS boost in this case. So I'm trying to figure out the 'sweet spot' if you will.
Edit: Sorry I meant the boot strap which is 100 for 2133 MHz and 2400 MHz.
