Well of course. You can't rely on an overclocked PC to keep all of your precious data and nor should you. Server CPUs also use ECC and ECC boards that cost a pretty penny.
And yes, many people will prefer core count. But then it comes back to what you need. It would be foolish to go out and buy an 8 cored CPU if you are never going to use all 8 tbh.
AlienALX, providing your rads have cooling capacity, then a standard heatsink and fan isn't going to outperform properly done watercooling.
Only way it would happen is a perfectly designed heatsink that is the size of a case.
Even then, both methods of cooling are limited by ambient temperature.
this thread is getting off-topic from the OP
Indeed. I know it was mentioned that the NH cools so well due to its massive size. I won't deny or debate that, I totally agree.
However, most coolers look the same. There is bound to be other ways of getting them down in size with amazing performance. GPUs run hotter than CPUs. Look what Nvidia's vapour chamber did for the 5 series. And that was some tiny little thing. Imagine that was the size of say, the dark rock pro, cooling a CPU that is way cooler than any GPU.
But there are always walls. Obviously as voltages decrease then heat will decrease with it.. I mean from what I can gather the Ivy will run on 3/4 of a voltThat's friggin insane !![]()
Heat is, and always was the enemy.. Right up until something craps out through just not being able to go further. I've seen a GPU for example go from 700 odd mhz to 1ghz, then refuse to go higher. And it's not down to heat at all, simply that the technology won't let it go any further.
Indeed.
It's funny really. Heat has always been the enemy. Yet, with Sandy, it doesn't seem to matter how cool you can keep it. Well, without going into the extreme cooling.
I do wonder why AMD don't allow to make the OS recognise two cores as one core, inverse hyperthreading, so that the power of both cores can be instucted as a single thread in applications that don't use many threads; if they can hyperthread to put more workers on the table for multithreaded apps surely they can concentrate workers into less more powerful units for single threaded or dual threaded apps?
For the higher extremes watercooling is still required on Sandy Bridge.
If you want you're chip to last more than a few months that is.
That would have to be built into the chip itself. It's not for the OS to decide merging cores together. Anyway with effectively splitting a thread across two or more cores to complete it quicker your more likely to incur errors I imagine. It'd be less efficient so consume more power. It's more producive to come up with an architecture that has a higher Instructions Per Cycle (IPC) per core then your keeping the multi-threaded ability.
