grandpatzer
I just built my first watercooling and I'm wery worried
I have put 2 picture of this build.
Q1: So if I run this setup for 24-48h with pump on and no leaks I'm good to go?
Q2: It seems like I have kink between res and waterpump, beside more resistance does this mean the tube will break aswell?
Q3: I connected a tube with fitting to fillport hole on case, but this metod is wery difficult as it is almost impossible to fit a tube with fitting to reservoire what other ways are there?
Q3a: So once I filled the reservoire and run couple of times I took out with big effort fillport tube and put on door on reservoir where fillport tube was, now there is air, how will this air be released from system?!
Q4: How do I bleed system now?
Q5: How do I drain and refill once I put in GPU + External radbox?
Q6: I want to drill out the harddrive cage but where can I install the res, there is no holes to install it.
Q7: The holes in the top of case where too big to screw in M3x30 screw to rad, so I had to use 4 screws for fans to case and 4 screw fan to radiator, is this bad?
First it seemed like my reservoire is leaking however now it seems like it might have been water from when I overfilled the res.
Now there is a 15cm (5inch) long air bubble when I turn off the PSU the air bubble goes throug cpu block and into reservoir.
My current goal is to add a external radbox + 360 rad and add a 7970.
