Hi all, I'm building myself a new "budget" PC as the old P4 one is getting ancient now
The components I selected are as follows:
CPU: INTEL Core 2 Duo E7200 2,53GHz (1066MHz) 3MBL2 WOLFDALE LGA775 - BOX
VGA: ASUS EN8800GT/HTDP/256MB or 8800GTS (I'm still not sure but I'm probably getting the GT as its quite cheaper
MB: GIGABYTE Sc 775 EP45-DS3, Intel P45
RAM: DIMM DDR2 2GB, 1066MHz, A-DATA, CL5-5-5-12 (KIT 2x1GB) Extreme Edition
HDD: WD CAVIAR BLUE WD3200AAKS 320GB, 16MB cache
Case: REDSTAR Happy16,400W,12cm fan
Questions: Does this look like a nice "ballanced" PC build?
Is it OK to buy a case from Redstar?
Is 400watt PSU enough to supply all the power even if I buy the GTS graphics?
Note: I'll be running XP, I'll update to vista only when it's absolutely needed (I want to keep my XP as long as possible)
Thanks, J.M.
Thanks, J.M.
