Building a new computer
Mushkin is alsmost impossible for me to get here in sweden, im having eez to find memes of corsair and adata, but i dunno.
It could be in the future i am going to overclock also..
Hello there fellow Swed
The Mushkin RAM IS avalible for us in Sweden.
Blackline
Blackline Stiletto
Silverline
Essentials
All found here.
Allthough I have to admit it's weak. No 6GB kits or so. I think they've had no breaktrough in Sweden, yet atleast. x)
Okay, so i am supposed to buy my components in 2 days... when i came across some people talking about Asus Sabertooh, and thay the motherboard is a extreamly instable, by the fact that sometimes the COU slot dosent work, the motherboard cant find any cpu installd on the motherboard, the 3 gb/s sata doesnt work, instable bios, alot of negative feedback, then i saw that its a new vg2 of the sabertooth motherboard, adn that onbe also in instable with bios and the cpu, also that northbridge goes up to very high temps, so my question is, is this some new discovred problems, is it worth buying another motherboard, as i want to spend some money on the motherboard as i will probably upgrade my system as the months go by, something worth putting money in is the board.. im thinking of spending 300 dollars on a motherboard, should i stick with the sabertooth, or choose another board?
I'd be inclined to agree with others, why not go sandybridge with your budget? It seems like a better idea to me personally overclocking is a doddle and you could potentially save a fair bit of money.
I'd go for a i5 2500K or a i7 2600K with a gigabyte UD4 or 7 if your budget permits.
As i already caculated my budget, im goinf for a sb, as i want a 960, maybe im a retard, but thers rly nothing that can cahnge my maind, if i have to put our another 100 dollar or 200, its a possibility, i got 4k dollars, its just that i dont want to spend it all on the computer, but i still want a 960, and later this year ill porb buy a gtx 580, i just want to know of a good motherbaord that stable, good preforming, can hold for an upgrade of compnents, and wihtin the same price range of the asus sabertooth, something around 300-320 dollars..
I might be think headed, but as im prob will go in to overclocking in the future, i would rly like to not go sb, still you can overclock it, but it just isent what im looking for, but if someone coulds tell me an altenative, good stable, preformance motherboard within the same price range of a sabertooth, i would be really glad.
And i sinnerly appriciate all the helo i get, rly... withgout being on this forum i would have failed alot, so im really tahnkfull for all the help you give me, just want to make that clear
Just wonderd, how bad is this? (my old pc...) Just asking sence i got everything in my list of buyings now i just want to know some things about my old componets
A Q6600? that's a decent CPU, heck, I'm still rocking a E6400
sure there have been some generations since the Core 2 days, but they aren't bad.
