Budget Watercooled I7 Rig
Deceit
Member
Just taught would post up my rig which I managed to build for under £600 including a 24" LG IPS panel monitor.
The rig itself consists of
I7 930
foxconn flamming blade gti (will be replace when can afford it so can put in my other 6gb ram)
HD5870
6gb Gskill pc12800 cl6 ram and 6gb Ocz platinum pc12800 cl7 ram
2tb Seagate Hd
750rasurbu psu
Utgard case
Watercooling setup
Dvd drive
24" Ld screen
Nice setup, how much did that waterkit cost you? P.s. Love the rocket ships on the wall lol
Edit* Did you buy all the parts new? How did you build that for so cheap? Or did you use parts from an old build?
Looks nice indeed!
EDIT: Tom it looks like its a Laing D5 pump, i reconize a bit of the standard top it comes with, look through the holes in the drive bays, first pic.
Tom its a laing D5 which I got for free of a guy as he taught I was a nice person
. Monitor I bought for 40euro broke and fixed it and minus the utgard everything was bought second hand.
Yea like the rocket ships myself
there my kids had them from when he was living with me.
It cost me about 100 euro in total which is abour 65-70 sterling for the Watercooling loop but I did get the pump for free.
The loop order is Res, pump, rad, cpu. First watercooled build so not too sure if is right.
Edit: Everything bar the keyboard, mouse, second monitor (silver one) and os was bought in the 600 budget including the desk.
Had to be really smart with my cash as going to go back to uni and money is going to be tight so did the best I could on the budget
jesus and i thought stepy was the king of bargains
Awesome PC! Even better for how much you put it together for, nicely done. What did you do to fix the monitor?
Thanks all for the comments
, yea am a left handed was a bad thing for gaming until the lachesis came out
. When can get a good deal on a waterblock for the gpu will do it, already have all the other fittings for it, will just need another rad and the block. Cant get a deal on an ssd so far also though
. Hopefully being patient one will pop up.
