Bright Bling Red PC60 Plus
Phil Stanbridge
Just thought I'd share a few piccies of my latest and greatest - its a highly polished red PC60 Plus, with modification to allow the PA160 to fit. It's actually running surprisingly well considering it's using a single C-Systems mag pump, but more on that later. Sorry the photos arent up to the usual standards but I'm struggling with my camera. It's not finished either, and I want some advice on grills!
Specs:
4800 X2 @ 2.52ghz (210FSB, 32 degrees idle, 7v)
Asus A8N SLI Premium (1009 bios)
MSI 7800GTX @ stock (35 degrees idle)
2GB Ballistix Tracer (faulty!)
250GB SATA II Maxtor (Zalman HD caddy, silenced)
Plextor PX716A
X-Fi sound card
PC60 Plus, red, polished, custom window, smoked perspex
Storm G4
NV78
C-Systems Mag pump
PA160
TubeRes
Vantec Strealth 120mm @ 7v
It's not quite finished as you can see, I need to add some grills to the top panel - I may stick a 120mm fan in there too in order to add some extra airflow. But what grills should I use?
Its my works pc - and demo rig. I prefer the res option all the time, its so easy to fill/bleed the system and in this particular system the res is tucked nicely out of the way. I'm very pleased with the overall system now.
Nice setup as always phil, nice deep ferrari type red, i really like it.
I think it's lighter than the PC70, that was more cherry than red.
Your EP-UK grills look sweet phil, make it distinctive and better looking with the tidy holes, underneath is definately better IMO.
Have you change your sig once you finish it :D
G
Is there anyway you can spray your epuk grills black? If you can I'd go with a couple of black ep-uk grills underneath.
I totally agree - fill-ports are a good idea, but nowhere near as practical as the trusty reservoir.
A gem as always Phil.
Mav
I'm not sure but I think Phil may have been planning on using a thermo he/pa120 series rad but realised it was too tight a fit, especially where the psu is concerned.
yep thats right, unfortunately the PA120.2 is slightly larger than the HE and I couldnt get it to fit comfortably without the PSU sticking out at the back. I can still make use of the blowholes however for fans or something, but at the moment its just not necessary.
