KapteinFruit
I got my WD Caviar Black today, but I got the same problem as my brother had which he can't remember how he fixed. I Google'd for help and came up with something that said I should go into the Repair Console and type in DISKPART then LIST DISK then SELECT DISK # (As an example SELECT DISK 0) then LIST PARTITION then SELECT PARTITION # (As an example SELECT PARTITION 1) then ACTIVE then EXIT. After that I should run Startup Repair up to three times, but the problem is that it doesn't find any problems... Can any of you help me here? I'm so effin' pissed off right now... First it took me six hours to finish downloading Portal 2 which should have been done over night, then I had to wait for ages for Steam to decrypt it, then I got the damn BOOTMGR bullshit and now the "solution" won't work...
And now when I've actually might have found a solution which is that I should only have one HDD plugged in when doing what I wrote above, the effin' "Recovery Tools" won't work... It says "This version of System Recovery Options is not compatible with the version of Windows you are trying to repair. Try using a recovery disc that is compatible with this version of Windows."..... What the hell can go wrong now? My mobo, CPU, GPU, RAM and PSU frying at the same time and then the case catches fire and burns down the whole apartment too?... DJSHFGJBGKSDBGKDBISDGHKSDJG<KFGGKD<KSGFkgK <------------------ That is me raging....
