Blue Meth! - A Breaking Bad Tribute
GamingDj
This project is a tribute to the Breaking Bad series.I am a big fan,and I'm sad it ended.I planned to make a new build anyway,so I will do a Breaking Bad crystal meth themed blue PC.Some of you may heard about Project Blood Dragon.This project is dead,because I had a car accident and had to spend PC money on a new car.The other drivers insurance paid,and I got more than I expected.I started saving up on this build.This project will be finished somewhere in 2015 - 2016.I have a lot of work to do,I have University,too.I do not have a lot of free time.
Components
CPU:Intel Core i7 4770K @ 4.5 GHz
Motherboard:Asus Maximus VI Extreme
RAM:32GB Corsair Vengeance Pro DDR3-1866 ( 4x8GB ) Blue
GPU:EVGA GTX 780 Ti 3GB Superclocked 3-Way SLI
Thermal Paste:Coollaboratory Liquid Ultra
SSD:Samsung 840 Pro Series 128GB ( Only OS and programs )
SSHD:Seagate Barracuda 2TB 7200RPM Hybrid
Case:Corsair Obsidian 900D
PSU:Corsair AX1200i Fully Modular 1200w + Individually Sleeved Blue DC Cables
Optical Drive:Asus BW-14D1XT Blu-Ray/DVD/CD Writer
OS:Windows 8.1 Pro 64-BIT
Peripherals
Keyboard:Razer DeathStalker
Mouse:Razer DeathAdder 2013
Monitor:Asus VN247H-P 23.6" Monitor x3
Speakers:Logitech Z906 500W 5.1ch Speakers
Headphones:Logitech G930 7.1 Channel Headset
Water Cooling
Pump:EK-D5 Vario X-TOP - Acetal (incl. pump)
Radiators:Alphacool NexXxoS XT45 Full Copper 480mm & Alphacool NexXxoS XT45 Full Copper 360mm
Reservoir:EK-RES X3 250ml
CPU Block:XSPC Raystorm
GPU Block:EK-FC780 GTX Ti - Acetal+Nickel x3 + Backplate
Fittings:EK-CSQ Fitting 13/19mm G1/4 - Black + lots of 45,90 degree fittings
Fans:Corsair SP120 Performance Edition Twin Pack x6 + Corsair LED Series 140mm Blue Fan
Tubing:TUBE PrimoChill PrimoFlex™ Advanced LRT™ 19,1 / 12,7 mm - Brilliant UV Blue (PFLEXA-34-B) x5
Coolant:EK-Ekoolant UV BLUE (premix 1000mL)
lol the theme is goan give cops probable cause to search the house for a meth lab hue hue u should try and impliment a custom reservoir that looks kinda like a bunson burner with a flask on top or what ever there called
Gotta love BrBa, you just can't beat it :D I'm interested to see what you're going to do with this theme :)
It's good you've got the money you deserve too because of that idiot driver.
Windows 8.. really?
With a build with this kind of budget (yes I'm looking at you 3x780Ti) I would get a much bigger SSD than 128GB, like 240GB/256GB minimum I'd say.
I'll read once that text size is fixed, truly annoying and out of proportion.
My time has been better spent writing this than holding ctrl+scrolling out to make it smaller.
*crushes some rocks and snorts the dust*
Okay lets get cooking.
Btw are you going to give us some samplers (pics)?
I see everybody telling me to get more storage.Well,now,with my current setup I'm using 43GB.I've got a partition of 200GB on my 2TB hard drive for windows and I've still got 156GB free space.This with Windows installed,apps and programs,etc.I do not need a bigger SSD,because I am storing my download and games on the HDD.
I will give you images,but you will have to wait a lot.I will only order the parts when I've fully got the money for it,not like I have 800$ and I will buy a single GPU.(My GF would kill me if I would stack the whole house with PC parts :P)No.I need like 7000$ for this build.I'm finishing Uni next year,then I will get a full-time job.This is when I will really get to save up.
As about text size,sorry if you find it too big,I just made it like this because it looks better :P .I will decrease it.
Will be interested to see what you can come up with in terms of a theme. It will be disappointing if you just throw the most expensive hardware you can into it, and just use blue liquid in the loop.
If it's a Breaking Bad tribute does that mean it's going to have a disappointing ending? :) (not having a go at the build here, just to make that clear)
