Lynx New member May 26, 2009 #1 Anyone know where i could get my hands on a set of nb, sb or mosfet blocks? Also could i run a cpu nb mosfet loop with a tripple rad?
tinytomlogan The Guvnor Staff member May 26, 2009 #2 As long as its a good rad and pump dude you'll be fine, for OC you dont need a sb block. Measure the nb block and see what blocks are compatable because I for one havnt seen any blocks specialy made for it
Lynx New member May 26, 2009 #3 Hmm, im sure the XSPC Delta Chipset should fit eh? Remember those swiftech ones? Where can i get them nowadays?
F f0x. New member May 26, 2009 #4 Are you installing this gear in the 900? is it possible to mount one internally? i dont like the idea of it mounted externally either tbh :S
