J joey117 New member Aug 25, 2012 #1 Can the bitfenix prodigy Fit a m-ATX motherboard is there enough Depth to the case .A m-atx is 240mm and i can mod the mortherboard tray if it will fit in inside the case
MadMarc New member Aug 25, 2012 #3 Google is your friend: http://www.bitfenix.com/global/en/products/chassis/prodigy/ The case is only mini itx and it dont think it's worth modding the case to fit an m-atx, even if it were possible.
