birthday build
yuyo12
okey guys, my birthday is close, so i am planning to sell my current build and pass myself to intel team! it would be a gaming rig, and i was planning something like this:
i5 2500k (deffo overclocking it)
cooler master v6 (can`t get noctua in my country)
Asus P8p67 b3 (not very sure about this one)
1tb hhd
nvidia 560 ti
Ddr3 Gskill 4gb 2x2gb Kit 1333mhz Ripjaws
sentey 600 psu(trying to find corsair but it is very difficult)
thermaltake V4(deffo not sure about this one, but just because is cheap)
that would be in a short period, and in some more time probably would upgrade my lg l177ws to a better/newer monitor.
what do you think?? i`m listening, any modification. thanks
1TB HDD, would help if you told us which one.
get the CM STORM ENFORCER
get a decent brand power supply, doesnt have to be corsair... mushkin, OCZ, Coolermaster, Be Quiet there are a few good brands
cooler = Get a dark rock pro or a silver arrow or something from corsair? maybe you can get the hydro series in argentina
the brand of the hdd doesn`t really matter, i don´t mind if it isn´t the best. the psu`s brands that arre available in here are: thermaltake, lianli, coolermaster and one xfx 650. they are much more expensive, but i understand it`s a key part on the building. and about the cooler, there isn´t any dark rock pro, and the silver arrow almost double the price of the v6, and i won`t be doing extreme overclock. just set the i5 at something like 4.5ghz.
WHAT DO YOU THINK ABOUT THE MOBO? is that a good choice or is there any other option to look around?
oh, and thanks for the reply. it`s always good to listen some other opinions.
mobo is good, to get a i5 @ 4.5 takes about 1.32 v on a noctua nh-d14 that equals about 60 degrees in england
in argentina its ALOT hotter so i think that will be about 70 and thats on a D14 only god knows what a V6 will do, the xfx psu's are decent mobo is meant to be decent have a quick look around on google
would help if you told us your budget and what site you would be shopping at
So long as the xFx PSU in question isn't a similar age to this one.
