bios update
What motherboard do you have?
You have a number of different ways, you can update it through a USB pendrive and you can do it through Windows (least safe!)
Those are the only two that I can think of at the moment, please can you add in what I have missed out guys.
You could back up your hard drive, though I don't think it'll make much difference if the update goes wrong because your board will be dead.
I used the Windows app. to flash my BIOS and it worked, so maybe that is something to consider?
alrite i flashed it successfully:D (so happy), however this bios doesnt support sli memory when more than 2 sticks are installed so i gotta find a different one:(. thnx for the help though.
