Hiya guys. I have been having some fun modding around my case/cases so I thought to get some feedback from you guys. It used have only one case but I got little carried away. When I first built to xigmatek white knight midgard it had amd fx-6200, amd radeon hd 7770, asus m5a99x evo motherboard and processor was cooled by noctua nh-d14. So when I think about it that thing has gone quite big leaps forward to what it is now.
Parts I used for this were:
Processor: Amd fx-8320 @ 4,6 1,3Volts
Motherboard: Asus sabertooth 990fx r2.0
Graphics card: Amd radeon r9 290 @ stock
Ram: G.skill ripjaws x 1600 cl9 (Still needs to be painted white)
Psu: Corsair gs800 (I know it's way too much for this setup)
Case: Xigmatek white knight midgard x2
Cooling parts that went into this:
Pump: Laing D5 VPP655-T12
Processor block: EK supermacy acetal (Filled those circles and painted plastic part white and those thumbscrews aswell)
GPU block: EK-FC R9-290X full cover block with backplate
Rads: Alphacool nexXxos UT60 240mm
Alphacool nexXxos monsta 360mm
Fittings: Phobya 13/10mm straight compression fittings
Phobya 13/10mm 90 degree angle compression fittings
Phobya G1/4 90 degree dual rotary adapter
EK waterblocks G1/4 45 degree adapter
Fans: Arctic cooling F12
WARNING These photos are not the best ones out there because they were taken with htc explorer :lol:
