R Rockindaveuk New member Jan 27, 2005 #2 name='gorby' said: Guys whats the best way to get DC4 off your cpu and mobo? Click to expand... isopropranol and cue tips (cotton buds)
G gorby New member Jan 27, 2005 #3 Dave, where can i get the former from, some kind of hardware shop.. Is it more commonly known as paint stripper or anything like that? Cheers
P Psykotik New member Jan 27, 2005 #4 Isolpropyl Alcohol or IPA, can be found at your chemists hopefully. I got a 2L bottle abut 4 years ago for about a tenner, and I haven't even used past the bottle neck yet
R Rockindaveuk New member Jan 27, 2005 #6 name='gorby' said: ahhh, wil TIM cleaner do then? Click to expand... Should do if its the alcohol based stuff.
P Psykotik New member Jan 27, 2005 #7 Yeah, don't use a citrus based one as you will not be able to correctly apply DC4 again afterwards.
F fatty New member Jan 27, 2005 #8 Use spray electrical switch/terminal cleaner non residue leaving stuff
R Rockindaveuk New member Jan 27, 2005 #9 name='fatty' said: Use spray electrical switch/terminal cleaner non residue leaving stuff Click to expand... yeah but dont do like somebody i know did. They got switch cleaner mixed up and thought WD-40 was the same stuff. You know the rest........
