Best Red Coolant
Lurid
So in your opinions, what is the best option to get a nice red for the coolant? I'd get red tubing, but if i'm paying $2 for tubing, them i'm going to buy Tygon. I know Pentosin comes in red, but IIRC in the concentrations we're using, its more pink. Anyone know of a nice deep(er) red? I'm thinking about ordering a few different brands, and seeing which is the best for my application :p
The UV dye at frozencpu.com is actually pretty good, UV tubes suck. I suggest clear tubes, pentosin red, and the uv red dye.
PrimoChill ICE is proboly the reddest coolant out there, the thing is you dont delute it with anything, h/e u could just get some uv dye and just dump a whole lot in the loop. This tubing is not UV active but it is pretty darn red. Here
I use the Danger Den UV Red tubing, looks perfectly Red and it means you can use whatever solution inside the loop you want.
I've also used the DD Blue stuff in the past too, never had any problems with it.
As for fluids, I've never seen anything perfectly red - in the UK at least.
Alright, i'm about to order a few different dyes I think. The most promising seems to be the red coolant on Petras. As they have a 9:1 ratio mixed, and the pic looks like a fairly good red. Also gonna order a few others, including Pentosin. Thanks for the suggestions.
