Warlord Shigs
right ive jus flashed my bios 2 the latest version p4c81016 and i seem 2 b havin problems gettin 270fsb plus on all of my p4 chips (3.0e,3.0c and 2.8m0). so i think it may b the bios. so which bios is the best 4 clockin?
name='aXeR' said:have you had your volt mods done yet?
Brwmogazos said:latest one is fine for me and for many others...
otherwise try the 1011...
i asked you on the other thread too
whats the stepping of that prescott you got?
if you can tell me what it says on the IHS would be great or in cpuz
Brwmogazos said:nope its not D0
someone with one is getting the following:
4.35Ghz in R404 Mach II is super pi stable. Max pic stable is 4.5Ghz
u never know
keep us updated mate
name='Warlord Shigs' said:well i was benchin it last night and i could only get it stable at 4.05ghz with 1.475vcore. but even wen i raised the vcore 2 1.75 i culdnt get past that clock. but that was with the latest p4c800 deluxe bios. i now went bk 2 1011, and im clockin it atm mate. so ill keep u posted ova the nxt few hours. and ye it is a C0 i jus checked. but i found a 2.8 m0 at work the otha day tho
Brwmogazos said:1.75V with the prescott?
better watch it mate![]()
Brwmogazos said:some chips just dont like voltage mate...
u using the latest bios for the board?
