Best GPU for budget
Benja
Hi guys I've done some looking around for a good GPU for decent settings gaming and there's a massive choice and i'm struggling to chose which would be the best option.
My budget for a GPU would be around £150-£200
MY current specs:
Intel Core i5-2500K 4.0ghz
ASUS P8Z77-V LX Intel Z77
Corsair Vengeance Low Profile Blue 8GB 1600mhz
Corsair CX600 600W
Thanks in advance.
That's nice, but in reality there's no difference between the two manufacturers. My 7850 performs admirably, so I have no qualms.
No need for 690s...
I'm not sure why you're suggesting the 660ti...
The 7950 beats it, and it's cheaper... - And regardless, it's out of budget anyway.
The 7870 is great for budget, as is the 7850. nvidia offerings seem a little scarce at that side of the market atm.
I think overall with the nvidia and AMD debate...
7xxx vs 6xx series - AMD wins this round across the board.
http://www.youtube.com/watch?v=kTujzlj11I8&feature=player_detailpage
Linus says 660 Ti is better :(
I don't know if that's correct though
It is incorrect, the 7950 is faster than the 660TI and is cheaper too. Basically from the 660TI and down the Nvidia range, AMD beats them on price and performance. The high-end market is a tough battle, but i lean towards Nvidia more just because the 670 and 680 are much more efficient than their AMD rivals yet are pretty much just as fast.
We've gone onto a debate between nvidia and AMD - talking about cards beyond the OP's budget anyway...
If you're gunna compare, at least compare the 7870 against the 660, otherwise it's kind of just pointless.
and with that.....
Get the 7870 ;)
and with that.....
Get the 7870 ;)
7870 vs 660
7870 wins :D
