Best fans for PA120.3
name='ai_01' said:
Yates, by far best price/performance ratio and nice an quiet
Which Yates would you recommend? The low, medium or high? Do the low speed push enough air, is it best to go for medium? Or are high good because the noise isn't that bad?
did you noticed in the review, they have different results with the same yates fan from different supplier? (Petra's yates fan have better results than others) so how can you be sure what fans you receive if you buying from a uk supplier ?
