Best case for under $150?
nezzarix
I recently upgraded my system and decided to continue using my Antec 900. Big mistake. Although it performs great, the case has absolutely no cable management. To make it worse, I went with a non-modular PSU this time and can't even close the rear side panel all the way. I'm been considering getting the NZXT Phantom but I've read mixed reviews regarding its airflow. Looks aren't important to me, I'm just looking for the highest performing <$150 case I can find that isn't a nightmare to cable
All comments/opinions are welcomed
I should also mention that I am using a Thermalright Silver Arrow so the case needs to be pretty spacious. I had to remove the panel fan on my Antec 900 and put it on the outside for it to fit.
Right now I'm debating between the NZXT Phantom and Cooler Master HAF932
I considered those but I can get HAF932 or Phantom for around $110 and would prefer a full tower case to make cabling a bit easier.
Ah right, how about the Coolermaster HAF X? Seams pretty good looking at reviews etc, not sure if Tom has reviewed it tho.
I would love the HAF X but it's a little bit out of my budget
Trying to keep it at 150 or below. Thanks for the suggestion though.
My vote goes to the HAF 932. Never used it, or the Storm Scout, but I love my HAF 922. At least until the Cooler Master Cosmos 2 comes out.
My vote is for the 932 it's a great case plenty of space good air flow 2 ssd slots but at the end of the it's your choice.
Have both haf932 and hafx,and i like the 932 a lot more.And there is much more space for a 60mm 360 rad,if you want to go wc.
Debating between the RV03 and RV02-E... Which one has more room for cables?
The RV03 has more room at the back plus the HDD mounts are at the back as well so all cables will be at the back of the case. See Tom's review on the RV03 on the Youtube channel.
