Hi folks.
4 days ago I recieved a bday gift (PoV GTX570 TGT UC).
The v-card is fine and I want to used it for increase my f@h ppd with my gtx460.
The problem:
Both v-card temps are too high when folding.
Gtx570 reached 93ºC and gtx460 reached 79ºC.
I had to remove the side panel of the case, and put a fan on a chair pointing at the rig to keep decent temps.
I would like to buy a new case to keep the system very cool, specially both v-cards without remove the side panel.
So, I need sugestions.
My budget is around 120 US$ (160 max).
I know that best cases are full tower size but I'll be great if I find a mid tower one which would meet my needs.
Thanks in advanced
edit:
I searched some and I like these but I'm open to another options
http://www.coolerguys.com/840556094623.html
http://www.amazon.com/Cooler-Master...UQAE/ref=sr_1_4?ie=UTF8&qid=1303064992&sr=8-4
http://www.amazon.com/SILVERSTONE-R...8KZG/ref=sr_1_8?ie=UTF8&qid=1303064992&sr=8-8
http://www.amazon.com/NZXT-Crafted-...9WQY/ref=sr_1_5?ie=UTF8&qid=1303064992&sr=8-5
The problem:
Thanks in advanced
edit:
