name='ai_01' said:Single gpu block w/ram sinks
name='kerochi' said:Can you give me an example?
All I can find are full blocks by EK and DD...
name='kerochi' said:Is the MCW60 the only single block that is out?
name='kerochi' said:So do you think I shud trade DD for EK?
name='kerochi' said:If I get a single block what would I use to cool the ram? Fans?
name='PV5150' said:I'm using the MCW60 with G80 adaptor on mine. The ramsinks can be extremely fidly to fit, especially when you get thermal adhesive tape that isn't as sticky as it should be![]()
