Best affordable Kraken G10 Cooler?
DatGameh
Hello. Thanks for visiting this thread, because I am going to build my very first build. And I know it seems overkill a bit, but I want to liquid cool my GPU. And a way to do it is by using the Kraken G10, without the AIO cooler installed.
But I live in Indonesia, and these are the coolers available in my budget:
1. Antec Kuhler 620
2. Thermaltake Water 2.0 Pro (The 3.0 version is more expensive here. This costs 10 bucks less in here)
3. Thermaltake Water 3.0 Performer
The rest are just too expensive. The lowest spec Corsair available here is the H75 and it costs like a H80i in my country.
So any suggestions? Please tell me!
P.S. I found a cooler, the Zotac GTX 760. It is the only reference cooler I can find, for compatibility and price in this country. Any thoughts if it is good or not? :)
I don't think you need a reference GPU for the G10 mate, you only really need a reference card for a full cover water block, when in stalling it into a custom loop.
According to NZXT, the compatibility listing is only for the Reference PCBs. I don't want to risk getting the wrong GPU, that is incompatible
If you loo at the mount for the cooler, it only mounts around the actual GPU socket and they are all standard. But I might be wrong.
If you see NZXT's Website, you can see that they say that they do not guarantee compatibility with the GPU. So it is a bit to risky
But anyways, which of the coolers are good?
