Best 939 SLI board ?
dbates
Is it still the generally held opinion that the DFI LanParty NF4 SLI-DR Expert is the best 939 SLI board out there ? My current PC has developed a catastrophic fault, so a quick purchase might be in order ;) How would the Asus A8N32-SLI Deluxe compare ?
I own the DFI SLI-DR and its been a cracking board for me and I have never had any problems with it. Although if you are not looking at overclocking then the Asus will do fine.
I will be overclocking, although not like crazy. I thought the 8-phase power on the Asus was good for that too though ?
Remember the asus boards have some vdroop problems when loaded but they can be modified. Just my personall experience, if you are running in a Lian-Li case that mounts the mobo upside down I would go with something other than the asus boards with the heat pipes on them. I had 2 A8N32 SLI boards fail on me because temps got too high. I did really like the board though other than that.
Officially, the Asus A8N32 SLI Deluxe motherboard is the best 939 SLi board available and the DFI SLi-DR Expert is the best 939 overclocking motherboard
unless ur going to use SLI , just get an Ultra-D. Sli-D and ultra-D are 99% similar. Same ur pennies and get an Ultra-D .
IIRC, if you're not going to SLI the Ultra-D is the preferred board over at XS even over the expert and such (and not just because of cost)
Because it tends not to assassinate hardware as much ;)
