best 140mm fans ad 92mm fan
Rob_the_scot
Iv orderd this case
http://www.sharkoon.com/sites/default/files/ddblock/nid-2058/images/manual_en_21398.pdf
I got to see this case in the flesh and I have to say its actually better than my fractal design core 1000 case, Any way I was thinking of replacing all the fans with non led summit with really good performance was looking at the Noctua fans for the 3 120mm slots but unsure what to use for the rear 80/92mm fans, any suggestions?
last but not least Best way to set up the fans?
1. starting from the rear fan run wire down side of case and daisy chain them all upto 1 molex
2. same as first 1 but hook up to a 3.5 fan controller.
3. 2 attached to mobo and 2 attcahed to molex.
Trying to think of the cleanest way of setting up the fan wiring
