hello people
im after some advice on what 120mm fans are going to be best to use for case airflow and also radiator use. i would kinda like to keep to the one brand for airflow and radiator use if possible as im sure quite a of you do to just to keep everything looking the same.
i will be using alphacool nexxxos monsta radiator
