Jimmy_Vendetta
This is my custom build which i tend to call Beast rig
It is a ever improving build which currently will be getting a SLI
set up really soon, more then likely 780 ti's also will be putting a sleeve
on the pump wiring as it looks messy as.
Specs
Silverstone FT02
Asus Maximus V Formula
Intel 3770k @ 4.5GHz
Corsair Dominator Platinum 1866 (8gb)
Corsair AX1200
Corsair Braided Cables
Msi Gtx 690
Samsung 840 Pro 128gb
WD Black 7,200 RPM 2.5 750gb
Magicool Extreme Triple 180mm x 35mm Slim Radiator
1x Corsair AF120
3x SIlverstone FN-181 *stock* fan's wired to high
XSPC D5 Dual Bay Reservoir with D5 pump
EK-Supremacy - Acetal Cpu block
EK FB ASUS Maximus V Formula Motherboard Waterblock
EK Water Blocks EK-FC690 GTX - With EK Black plate
10/8mm (8x1mm) Compression Fittings G1/4 - Black Nickel
Masterkleer Tubing PVC 10/8mm
Specs
Silverstone FT02
Corsair AX1200
Msi Gtx 690
1x Corsair AF120
