JesseLactin
Hi guys. I've developed an unhealthy addiction to Folding @ Home. I looking to put together a new rig in October. Looking at (real) liquid cooling, I'd basically be putting a new rig together. I can salvage the CPU(Phenom II X4 955) and RAM (Corsair XMS3 1333), but my HAF 922 has 20mm spacing, so it's not compatible w/ most rads, my crappy Biostar A800GU3 is has single PCIe 2.0 slot, and my Enermax Noisetaker 485W PSU (used, bought from a friend to $40) is barely enough to power a GTX 560 Ti.
As far as water cooling goes, I made a thread about single vs dual loops. I was advised to go with a single loop. If dual loops are better for GTX 580s in SLI, I'll do 2 loops later.
Rig components:
Gigabyte 990FXA-UD5
Cooler Master Cosmos 2 (Oct. -ish release date, prob. earlier)
Corsair AX850 or better
EVGA GTX 580 (not for a while, I don't have $1,000 to blow) + EVGA Hydro Copper II block
Custom Water Cooling:
Cooler Master SickleFlow 120mm (are there any better fans for under $10 CDN?)
XSPC RX240 (or RX360, or both) -
XSPC X20 reservior \_ may order XSPC Rasa kit for Dazmode.com
XSPC Rasa water block /
(14') 1/2" tubing
1/2" barbs(10 pack from DazMode.com)
(probably 5, they're only a $1.76 ea) 6" y-splitters
I got 2 questions is should I get diff fans, and is a 240 rad enough for a CPU + GPU? Or should jump to the RX360, or both together? I'd like to future proof my cooling solution for BD + GTX 580(s). I'm ordering the fans first on Monday. (NCIX doesn't process on weekends.)
Oh, yeah, for answering my nooby questions, thanks.
Rig components:
Gigabyte 990FXA-UD5
(14') 1/2" tubing
