Backplate on an Aircooled GPU?
RadeonHDx
I have been wondering for a while if this can be done and if so, if people think it will be worth it to put on a pretty bent AMD 7870?
Just for aesthetics or to add extra support for the card? Pretty sure you don't have to have a water block for a back plate.
Well, I really do like the looks of backplates instead of a raw PCB, but I also really need the extra rigidity of the backplate too.
Something like this - from ColdZero
These come either for stock or watercooled with fittings for either and they have different designs.
pretty sure you can use a backplate without waterblock, as long as it fits your card ofc
you'd probably have to take the cooler off to install it though
