atx case help please
crap-at-games
Hi all im looking for a case to fit some parts in and wondered if someone has got suggestions i dont really want to spend more than £50 and dont mind if window or not thanks
parts are
mobo msi z77
psu evga 430
hd 1tb western digital blue
cooling H105
ram corsair 1600
graphics evga 750ti sc
many thanks in advance
Hi Davva thanks for getting back to me i really like the look of the corsair SPEC-01 and the Corsair 100R but when i click on the cpu compatibility button it does not say if the H105 will fit and i would like to be 100% sure that it will fit before i order is there any way of knowing for sure ?
I honestly don't know any of the cases on that list. I can't vouch for them. I know it's not inside your budget, but I can vouch for the fractal define S https://uk.pcpartpicker.com/product/svVBD3/fractal-design-case-fdcadefsbk . It's a great case to build in, and offers great expandability IF you are looking to go custom loop later (it's not perfect - low # of drive bays, no fan controller, and no optical drive might ruin it for you). It's about 20 pound over your budget too.
Tom even gave it a White Gold award. Might be worth a look.
The gamemax cases are pretty awesome I loved the features of their Falcon chassis it's so much case for £40.
Aye, after a quick Google image search, I can see where you're coming from :)
Only thing that bugs me is the cheapo steel inside, but then again, it's only £40 as you say, so it's understandable.
Not as cheap as you'd think, I reviewed one last week. Very solidly built.
