ATCS 840 Problem w/ Fan Fiter
bwin
the filter under the psu cannot be taken out to be cleaned because it is blocked by the other fan .. any1 have the same problem?
I take it you have installed a 120mm fan in the optional slot at the bottom?
If so, i would perhaps remove the fan to clean the filter. But tbh, the filter is very flexible, the only sterdy part is the handle. Just push down from the top and gentle pull it out, it wont get mis-shaped.
