looz
Active member
So you're saying this is a better deal because this one has less pixels?and they are tn as well, and probably dont require as much graphics horsepower.
So you're saying this is a better deal because this one has less pixels?![]()
As long as we talk strictly monitors, that is more or less what's being said. Of course this one still has the advantage of gsync.That's not what was said at all bud, No idea how you came to that conclusion.
Simply implied that this ROG monitor would be easier to run than a 4K screen even though it is a lot more expensive.
When mine arrives, I will put them side by side and compare it to the PB278Q
You do realize you just paid £700 for a 1440P TN panel right ?
You do realize you just paid £700 for a 1440P TN panel right ? That's £100 more than a 4K screen costs.
A 4K SCREEN ?!?!?!
Dude, QuietOne must have a good enough reason for going for it.
Perhaps he wants to have a playable experience with a single card and perhaps wants G-SYNC! He also might want higher framerate.
While the 4K panel is cheaper, users may prefer a lower resolution with higher framerates and no visual tearing. Visual tearing is a big issue to lots of people.
I only have a single 780 for now and I am used to 1440p but I never had a monitor which was above 75hz apart from the CRT days. So going from a 60hz 1440p to 144hz with G-Sync will be an interesting experience.
On a side note, do Scan just have a generic delivery date regardless if it's a pre-order? When I ordered mine it said it will be delivered on the 1st of July even though it says they will have it between the 24th and 29th of July.
Best bet is to ring them up, Scan aren't very reliable when it comes to dates.
Thanks, I will do that in the morning. Would be nice if I had a nice surprise on the 1st but I highly doubt it![]()
You should work in the customer service industry or be a weather reader, You have quite the robotic tone, Kind of reminds me of a newscaster
Still though I think my man card would be taken off me if I bought this monitor, 1440P and £700 just seems retarded to me, £599 yeah that would still be expensive but would be feasible.
As it stands right now, Just no.
I do understand your opinions Dice, all I'm saying is that we shouldn't rag on QuietOne's, or anyone else's for that matter
Huh, guess so. I better sleep this alcohol off and return in better shape tomorrow.But what you said was completely the opposite to what was stated, I think this is a language barrier problem ^_^
I think you misunderstood me bud, I'm not raggin on Quietone I hope he has an awesome experience I'm ragging at Asus for such a retarded price on a 1440P panel
Also where did you get your QNIX from, I've heard good things.
I got the Qnix from AccessoriesWhole on Ebay, I wrote a review of it here if you want to see that.
It is essentially the same as the ASUS PB278Q, same panel connections etc. Just the panel is not A+rated by samsung at the factory, but nobody can really see the difference TBH, provided you get a checked panel for no dead pixels!
As for your comments, sometimes they can be read the wrong way that's all. You seem like a good lad though.
