Master&Puppet
I think ASUS have done a good job here but no less than I would have expected from any of the GPU partners. I think it is over priced though £499 RRP is very near to the bottom of the 780ti territory and I'd choose one of those for an extra few quid over this. It's too large a mark up for a cooler for me.
You can get a full EK water block cover for a 290x for virtually the same price as this and that is leagues ahead again if you've already got a custom kit for your CPU like many of us do. £440-470 is a more sensible price range IMO although getting free games does help quite a bit.
I don't see why people are getting upset about the 'heat issue'. AMD designed these cards to run hot. That means that it is warrantied to run at 95C at full load for the length of the warranty period or they'll have to give you a new one. Likely scenario is that it will outlive its usefulness before it breaks.
As for worrying about dumping hot air into the case for the rest of the components to absorb? Well its TDP is only 40W greater than a 780 which can't account for more than a couple of degrees and that will only make a difference if all your components are already running on their limits too.
