Asus Maximus VI Extreme - always entering in BIOS after reboot
windcoast
hey guys,
i would like to ask a big problem with my motherboard Asus maximus VI Extreme and video card Asus Mars 760. My OS is WIN8.1. After instaling driver to video card Asus Mars 760 in win8.1 always is ok - work perfect, BUT ....
When computer is off and turn on always is normal and loading WIN8.1 (although it seems a little slow passes check the BIOS), but when i use restart the system always entering in BIOS after reboot. Any ideas?
Pls help!
Thank you for your kind help.
Is it on the latest bios?
Normally a restart misses the bios option completely (very annoying when benching and you have to shut down completely and manually switch back on to get at the BIOS :p )
Thank you for advice tinytomlogan. I'm not sure that this will solve the problem. I would'n add any additional hardware in the last 6 months. The problem was not in the beginning, and appeared much later, so I guess. that one of the children has changed or settings in the BIOS of the motherboard or BIOS settings of video card.http://forum.overclock3d.net/member.php?u=8821
Can you please just update the BIOS - there are a series of things that need to be done so that we can work out what the problem is. BIOS is first seeing as it shouldnt be software.
A BIOS clear is required and you might as well update it while you are there. Otherwise I cant / wont be able to help you any more. Please attach a screenshot afterwards showing the BIOS on the latest available.
