Hey, I wrote this review a long time ago just figured I would share it with the community. It's not very long but it gives you a general idea.
When I recieve this case from Newegg.com, the first thing I thought was that the box was huge. It came with styrofoam on each end for shipping protection but left the center vulnerable. The case was covered in a plastic bag case and the window and front mask had a plastic protection cover. The case has a beautiful finish and the fan guards look good too. It comes with optional masks to replace on the front of the case my personal favorite was the silver. There are no real instruction besides the ones on the side of the box. And written instruction on how to replace the mask.
The case 6 slots for fan 5x80mm and 1x120mm. The stock fans are good fans as far as I can tell. It is a very blue lit up case and looks great. Easy acces side door opens and it has a nice mobo tray not removable though. Comes with keys so when at lan parties someone doesnt get sticky fingers. Included is a fan controller and temperature sensor on the front of the case along with two usb and 1 firewire port. 4 Drive bays and 2 floppy drive bays. 3 removable hard drive mounts. Large and lots of air room for air to move around. Comes with the slide in slide out drive mounts for ease of use. An overall great case.
The power supply. Absolutely need to upgrade the powersupply. It may sound good but trust me it isn't. It is pretty unstable and doesn't seem to put out it's max wattage. Make sure to replace this.
That's all for now.
-MikeEnIke
That's all for now.
-MikeEnIke
