Dawelio
Active member
Hey guys,
So I have a bit of a dumb question...
I have an Asetek AIO, which is similar to this one, only a smaller unit:
Now I am a bit confused on how to connect the pump and fan to the motherboard.
I have 2-3 headers, one is CPU_Fan and the other(s) are OPT_Fan or Fan_1.
I read on another forum that you should connect the pump to the non CPU header to let it run at 100%, as it ahouldn't be controlled. And the fan to the CPU_Fan, which I then believe can/will be controlled?...
I've tried finding an more solid answer, but doesn't seem to be one and I've never encountered this issue before with an AIO. Since I've had Corsair AIO's which has had an different design, ie you could connect the fans to the pump itself and it controlled them. But not like this, so I'm confused now?...
Thanks,
Chrazey
Thanks,
Chrazey
