ASAP - HELP REQUIRED
  • Thread starter Thread starter Deleted member 9280
  • Start date Start date
My work is very poor, as you can see...
It'll be easier to have a simple background because on high resolutions like mine (1920x1080) the background starts to appear twice as it isn't big enough.
I have noticed this problem, but do not understand why it is repeating/tiling... I have set it to be fixed and not tile but it is anyway... confused much?
Only problem about an image that big would be the file size
Sorry for the late reply, been a bit busy.
Could it be possible for one of you guys to do what he had requested?
Just take a cut out of the background and add it onto a layer beneath the transparent header.
Should work.
Thanks dudes.
Should work.
Thanks dudes.
That works,the only snag is,knowing which part of the background to put behind the banner.
EDIT: tried to put it "somewhere" in the right area
