This project started from buying a broken prom mach1 off ebay and it went from a 'repair' into this project.
I'll let the details speak for themselves, but I think it's turned out quite well. Quite a few hours work went into making it all pretty.
Full spec...
NL11F Danfoss compressor (from the old mach1)
Kayl's head and enclosure
Johann's flex line
Original condensor from the (from the old mach1)
402a blended gas
Sunon fans back and front
2m x 2 EL wire on the suction line
Golden Froster XE with module
3.5mm ALU checkerplate base
Laying it out for the build
The suction line getting it together with EL wire and Kayl head
Shot in the dark (no not the Ozzy Osbourne song)
The suction line got heavier flex that holds it's shape and will take a little more abuse when manhandling it for different socket locations. 2.95m of .031" captube, EL wire under the braid, and Kayl head for performance and of course that pretty mounting plate too.
Sprayed the condensor to match the silver case
Full spec...
Johann's flex line
402a blended gas
