Davidthewin
i5 3570k running on a Gigabyte GA-Z77x-UD3H with a H100i with SP120s in push at 1600RPM.
It's running at 40 multiplier at 1.1V in the BIOS with LLC on extreme. I haven't overclocked before so I watched TTLs 1155 guide. I managed to get stock clocks stable at 1.05V (stock volts are 1.12) and after 30 minutes of the test below, 4GHz seemed stable at 1.1V.
Sorry for the resolution, but the important part is that one of my cores is touching 72C whilst one is sitting cool under 60C. Is this normal? Should I push it further?
On an unrelated note, I'm pretty sure Link is bugging out with my H100i coolant temps, because on a 60C+ CPU I very much doubt the coolant is 32C. Also I have no idea what is up with the "VBAT" reading on OCCT.
update/
Did a quick prime test and got
Also ran OCCT with RealTemp to check that OCCT was checking the temps correctly and they agreed with each other
update/
