are these fans and fan controller any good
gampla
i want to replce my two stock antec fans and add a controller to my build but i cant decide if there any good
fans 2x cm jetflo 120mm
controller aerocool v12xt
What are the fans for? They are more of a raidiator or CPU cooler type of fan than a air flow case fan.
The fan controller is ok though,I prefer non touch screen ones personally, but as far as I know there is nothing wrong with that particular one.
All good then, they have good specs and are just as good if not better than some of the other fans out there.
im running 3 sickleflows atm two as exhaust and one as intake.
what would you say i can replace to stock fans with as two more intake fans?
green are intakes
red are exhaust
Just go with the fans you like best, as long as you go for ones with decent specs any fans will do. Best fans for cases ar ones with as high of a CFM you can find with the lowest DB.
The higher the CFM the more air they blow, but you don't want to stick ones that sound like hoovers in your case so find the quietest one with the lowest DB.
Off the top of my head The Corsair AF or Cougar Vortex fans would be good choices.
tbh i dont really care for fan looks aslong as they perform well http://www.scan.co.uk/products/ener...stable-peak-speed-halo-frame-twister-bearings
http://www.scan.co.uk/products/120m...-airflow-and-low-noise-1650rpm-6347cfm-30db-3
I don't know anything about the Enermax fans tbh, the corsair ones are good though. Personally i'd go for the Corsair ones unless you wan't LEDs.
led would be a waste the fan in front i couldnt see it throught the dust filter and the one in bottom same again i would be able to see it
