ARCTIC COOLING Release The Turbo Module
Is it me or is that just 2x50mm/40mm fans :confused: surely a case with good airflow would be just as good?
also what sort of CFM would they push? 6cfm per fan? (@25dBA?)
I know I'm being sceptical, but I wouldn't of thought you'd see that much difference and it seems to be another one of those gimmicky things.
You would prob be better to get a "Vantec UV LED Blue Spectrum Fan Card" which has 2x70mm fans @ 30cfm. (or just not waste your money) :p
name='Kempez' said:
Well the cooler is already very good so I'd imagine it only needs a very slight breeze to get it even better
If the cooler is already good, why the need for extra addon cooling? :)
Will be interesting to see how many "enthusiast gamers" buy these :rolleyes:
Look forward to some results tbh, the cooler on it`s own seems pretty attractive, we`ll see what sort of benefit it gives.
Be interesting to see using this vS strapping on u`r own larger fan. U`r fan won`t have the nice little grips on it, but I`m sure that`s work-aroundable.
ducting I guess :)
altho as Kempez said the cooler itself looks good, so there probably is no need for the extra cooling if you already have a breeze/good airflow in the case.
Aditional cooling is never a bad thing if your overclocking TBH. My 7950's slient cooler is fine, but i mounted a fan onto it just for extra security.
