L larkva New member Dec 2, 2010 #1 Does it perform well, and easy to have a clean build. i do like Clean looking cases, not a big fan of Hafs and antec. Iam going to buy a new build with an asus 580 and a i7 950, and i like to keep my components cool.
tinytomlogan The Guvnor Staff member Dec 2, 2010 #2 Ive not had one but looking at it I have to say it wouldnt be something I would buy/use
L larkva New member Dec 2, 2010 #4 tinytomlogan said: Ive not had one but looking at it I have to say it wouldnt be something I would buy/use Click to expand... Ok Thanks, any particular reason? things to avoid when looking for a case
A AMDFTW New member Dec 2, 2010 #5 airflow build quality if it suits ur needs water cooling or air cooling or both space mobo space ,HDDS etc features such as tooless motherboard tray coler
L larkva New member Dec 2, 2010 #6 AMDFTW said: airflow build quality if it suits ur needs water cooling or air cooling or both space mobo space ,HDDS etc features such as tooless motherboard tray coler Click to expand... Thanks for the help, iam not sure how easy it is to get the silverstone in norway, only seen a couple of models, and the lian li, well i am not a fan of the leds. but if its got an of swich, its an alternative
A AMDFTW New member Dec 2, 2010 #7 i think its just the fans mate that are blue. its a maaasive case mate
L larkva New member Dec 2, 2010 #8 AMDFTW said: i think its just the fans mate that are blue. its a maaasive case mate Click to expand... and it cost 300£ for a standard black model in norway, so its a bit pricy, the x1000 cost 20£ less they got leds
