Any good for a UPS?
Hi kempez815 :wavey:
This will give you a little bit more info on UPS's
http://www.sysxtreme.com/showthread.php?t=452
I am not really familiar with the brand that you have posted, but that's not to say it isn't worthy of your cash. Just check that the battery life is going to allow your computer to save and shutdown, so you don't lose any work. The guide should help you, and any other questions lemme know :)
We use some pretty basic ones at work and we LOVE them... We have our register computers with all of their peripherals hooked up to one ups / station and they've saved our asses a few times during short power outtages.
They are definately worth the investment, just do your research and get urself a good one. APC is always a name you can trust!
name='kempez815' said:
Right well I've seen an APC one but its quite a lot more money. I'll take a look around. Thanks guys :)
Nothing from APC comes cheap but it's like the PCP&C of the UPS industry :)
FFX whats a UPS well to quote the Guide King
PV5150's UPS Guide said:
What is a UPS
A UPS is a backup power unit that provides continuous power when the normal power supply is interrupted. UPS systems can be stand-by, only supplying power when the regular supply is interrupted, or fulltime, relying on regular power and/or batteries to supply it while it supplies power to the protected device. A UPS is not always necessary on most computer systems, but can be important on systems that need to be up 24 hours a day, such as servers. Bearing this in mind, UPS's are a necessity if you live in an area prone to electrical storms, brownouts, surges or outages. There are three levels of power protection available to the home computer user. The levels are:
1.Surge Suppressor (These are basically a fancy fuse between the source and your hardware; they clamp down spikes, but can't fill in a low voltage level or dropout. This is a bare minimum level of protection that any piece of expensive electronics should have);
2.Line Conditioners (These devices filter noise out of AC lines. Noise can degrade your power supply and cause it to fail prematurely. They also protect against short voltage dropouts and include surge suppression.), and
3.Uninterruptible Power Supplies ( Firstly it filters the power your machine sees, smoothing out spikes and voltage fluctuations that can stress or even damage your electronics. Secondly, it provides a certain amount of dwell time in the event your power goes out entirely — this can often get you through brownouts and short blackouts. Third, when the UPS is about to run out of power it can arrange a graceful shutdown of your computer so that no unpleasant things happen to your disk filesystems).
check out the AMPERE Hours on that thing for 230 Votls see if its worth it
*chants* BUILD THE GETTO 1
, pity tey bl
name='PV5150' said:
Yeah I might build the ghetto one as a project, what ya reckon Joe? :D
hell yea go for it :) make it a really beefy fuxer be able to run ur PC for like a day strait ,that would fuxing rox but how many batts?? -- for a 300 watt (actual power use) pc @ 230V you would need a total of 32 AH power reserve
yo kempez the ghetto 1 from PVs UPS guide http://www.dansdata.com/diyups.htm
