Antec KUHLER H2O 920 Or Corsair H80i
GamerMan3D
Hi i am going to be buying either the Antec KUHLER H2O 920 Or the corsair h80i. They are both around the same price so i want to know which gives me better cooling.
If I remember correctly from a review I read a while ago, the H80i has slightly better cooling capabilities. The 920 is still a very good cooler though.
With that said, I own a H80i and it's given me nothing but problems. If I had to pick a cooler again, it'd be the 920. Obviously not all H80is are temperamental; mine just is, haha!
either way, you'll be suprised at your temps if you've never used an all in one or custom liquid cooler before. suprised the shit out of me, actually got limited by my motherboard of all things when it came to overclocking, 1.3v is the max it allows, i was getting ~71-72 in prime 95 at 4.7ghz on a dinky little h70. Cant go higher because i need more volts, decided to stay at 4.5 which ... on the h70 in prime 95 scores better temps than stock clock of 3.5ghz on stock intel cooler 62-63 max after 15 mins. :o
Holy shit you can overclock the hell out that cpu
